AnEv942
Dec 31, 2019Nomad
Sorry not the magic bullet...its the charge line in from truck. Comes from thermal breaker that goes to umbilical cord. Previously was attached to the battery side of another thermal breaker that feeds front jacks (direct tie-in to battery). Issue was when camper batteries turned off the umbilical cord was still hot so moved it to the battery terminal thats no longer hot when disconnect off. Secondary was I added power disconnect switches to jacks- truck would power front jacks the way it was wired even if batteries off and jacks power switches off. At anyrate the black wire I show doesnt relate to your problem.
i wasnt clear on your voltage check. Was the voltage drop at load noted at the converter battery pos terminal? The Converter pos remained at 13.5?
Converter on, you should see same voltage (output) at both terminals.
Converter off, you should see same voltage (battery voltage) at both terminals.
I am curious about the battery voltage of 13.0- had you charge with somthing else?
