ticki2
Jan 01, 2020Explorer
Unplug the converter . At the panel disconnect the wires from the battery and converter lugs . Do you have continuity between the two lugs? How have you been charging batteries if the converter is not doing it? With the voltage drop in your last test between converter at 13.5v and battery at 12.7v I suspect a bad connection or faulty battery .
