biggjb
Jan 02, 2020Explorer
Ticki2
I disconnected the battery and converter on the panel and there was no continuity. I then connected the converter back to the panel and turned the converter on and the voltage coming from the converter was 13.65. however, just for giggles I checked for a voltage drop across both positive lugs of the converter and battery. There was a voltage drop of 13.65 volts. This made no sense so I tested it several times and it came out the same each time.
As for charging my battery I also have a 130 watt solar panel which kept the battery charged.
