Mr4btTahoe
Jun 26, 2017Explorer
Well.. main reason for buying this unit was because I was planning on building one from scratch.. and this unit has all of the appliances, power jacks, awning, heat, ac, shower, toilet, fridge, stove, all plumbing is new along with pump, tanks, etc.. all in good shape. I got it for less then the cost of a couple appliances from what I was pricing out.
The work involved doesn't scare me by any means... I can strip it down to the frame and rebuild from the bottom up if need be (which I don't think will be the case). The jack points are all solid. The cab over bunk area seems solid. The main rot is where the roof meets the walls and the roof itself. To be certain I don't overlook anything.. I was just going to strip all the siding so I can see the entire frame and replace anything that needs it.
I'm not in it for much coin.. and it came with the majority of the materials to re-frame the entire unit if need be. The guy just lost interest as his work schedule just wasn't allowing him time to work on it.
Here are some pictures.. yes it's ROUGH on the inside.. but that's ok.
Now the bad...
A lot of what I'm seeing in the walls is wet.. but not rotten. The only rot I'm seeing is up by the top. The whole roof will come off and be rebuilt from scratch.
So anyways... I just figured it would be a safe bet to strip the siding and make sure nothing is missed. I don't mind the work and have a lot of experience in light fabrication and wood working. I should be in it for less then half it's value when done.. and that includes purchase price.
Thanks for the quick responses.
-EDIT-... apparently I cant post links to photobucket? See if this works...
Now the bad...
44,056 PostsLatest Activity: May 04, 2014
