Mr4btTahoe's avatar
Mr4btTahoe
Converting from traditional aluminum siding to smooth skins?
New to the forums...
I just picked up a '97 Sun-Lite 865 for cheap that needs a lot of work... Roof is completely gone and has some wall rot.
The exterior siding is going to have to come off for the repairs (siding is in great shape).
While it's off, I was considering converting to smooth exterior skins like the modern expedition style campers.
Has anyone tried this?
The only problems I can see coming up is the need for the camper to flex and move while in motion.. and smooth hard sides glued in place will make the whole thing rigid.
If anyone has attempted this and has any input.. please post up. Post up pictures too if you can.
Thanks!
  • There is long pictorial when one of the member had his camper rebuild at his local RV shop.
    The procedure is not cost-efficient and gluing big panels to the frame is a job require several people.
  • Nothing is impossible with enough time, money and determination, but... from what you describe, should you reassess and reconsider the work ahead of you?
    I have done my fair share of cab-over nose repair and while it was a descent amount of work, I do not think it was as extensive as you describe... just saying.
    if the siding is in decent shape as you state, can portions of that work be performed from the inside?
    Pictures of what you are up against will help us help you... post some up so members can better assist you.
    (not trying to dissuade you, but rather posting basing on just your words alone.)
