TakingThe5th
Dec 23, 2017Explorer
Have you checked for a coolant leak after a short drive before the thermostat is fully open? A sticky thermostat could cause a temporary pressure increase. I'm wondering if that excess pressure then allows coolant to get past the gasket on the recovery tank.
If not a cold engine problem, then maybe you get a lot of turbulence when the thermostat is fully open which increases pressure and allows leakage at the tank. I say this because back in the day when we would run an engine without a thermostat we would get a better result if we installed a restrictor plate. Not suggesting you do that but it gives you an idea of the turbulence that can develop. I would think the radiator would dampen the turbulence but, for me anyway, the proof was in the pudding.
In any event, I also wonder about the neck of your recovery bottle and it's ability to hold back the coolant - a rough spot, a burr, etc. Before you swap out the van you might want to just swap out that whole assembly - bottle, cap, hose - and see if that helps.
Have you peeked under the hoods of other similar cars? Is it a common problem?
Hope that helps. Good luck.
