- coolbreeze01Explorer
boogie_4wheel wrote:
3rd Gen Cummins requires the HOAT coolant. Yes, use distilled water.
Correct....... - boogie_4wheelExplorer3rd Gen Cummins requires the HOAT coolant. Yes, use distilled water.
- rhagfoExplorer III
donn0128 wrote:
Yes, but, before you do that, how are you going to dispose of the toxic waste? Used coolant is toxic waste afterall. And do you have Cummins approved coolant and not some cheap junk found at the local auto parts store? Cummins is very specific about their coolant so be careful not to use the wrong stuff.
Well two things, Cummins ISB 5.9's use standard Prestone or Zerex anti-freeze. Cummins is a non sleeved engine the block and cylinders are all one piece. Ford and GM both are sleeved engines and require special anti-freeze to prevent cavitation of the cylinders.
I run a 60%/40% mix anti-freeze/water, if you look at the charts this mix gives best corrosion, freezing, and overheating protection. - eHoeflerExplorer IIAlso, the newer engines use a different coolant than the old days, Dex-Cool comes to mind, it is usually orange or red. It has a mix ratio of 2 coolant to 1 distilled water to get max benefit from the coolant.
- donn0128Explorer IIYes, but, before you do that, how are you going to dispose of the toxic waste? Used coolant is toxic waste afterall. And do you have Cummins approved coolant and not some cheap junk found at the local auto parts store? Cummins is very specific about their coolant so be careful not to use the wrong stuff.
- JIMNLINExplorer IIIThats what I use in all of my trucks.
