Baja_Man
Oct 12, 2022Explorer
Correct Sealant for Windows, Marker Lights, Rain Gutter, ?
I use Dicor Lap Sealant self-leveling to touch up fixtures on roof (vents, TV antenna, front and rear seams, etc).
Now I want to caulk around some areas that appear to have a clear (but dirty) sealant. It does not appear to be a lap sealant. It is a factory sealant as original owner never sealed anything (although trailer was covered).
These areas include, windows, side/front/rear marker lamps, rain gutter, water, TV,, 120V plug and several other items on sides of trailer.
I know NOT to use silicone anywhere on an RV.
What is preferred sealant for these areas?
How to clean/prep these areas prior to application?
Are there just two sealants used on trailers.....roof (lap, self leveling) and one for everything else?
Is lap self leveling used on the last 4"-5" of front and rear seams (between front fiberglass section and rear wall) that are essentially vertical? I have a crowned roof. I was worried the self leveling sealant would drip down if applied on these areas. Currently it appears to be lap sealant (white, not clear).
Thanks!
Thanks!
