popeyemth
Jun 25, 2013Explorer
Once the coating is gone from the metal on the pins they give trouble from then on
Bite the bullet and replace them both
It's not worth chancing a wreck because your signals didn't work or were too dim to see.
Putting grease/lube on the pins is a PREVENTATIVE measure and won't repair the anti corrosion/rust coating that has worn off your pins.
Good Luck, Mike
Good Luck, Mike
