QCMan
Feb 17, 2021Nomad III
I can't comment on the Minnie as I have no experience with them. I can say that the Cougar 22RBS that we have has had no major issues and only a few very minor issues. Like all trailers, there are shortcuts taken to reduce weight like thin shelving which I beef up with 1/4" plywood on top and braces underneath. That makes it so canned goods do not end up on the next shelf down if a road gets a little rough. I was impressed with the chassis structure and suspension as it is about 7200 pounds mgvw and has two 4400 pound axles under it and a set of tires capable of almost 10 k pounds.
I will note that this unit was built at the end of October 2019 so it was pre covid. There were many issues with all trailers right after production resumed and I cannot verify that things are back to normal. If they are, quality should be back up but it must be noted that serial number 42 could be a fantastic trailer and serial number 43 could be a real dog on just about any trailer line.
Also realize that after negotiations the difference will not be as much as you suspect.
Whichever you choose, happy camping and be safe!
