wing_zealot
May 15, 2023Explorer
There is likely a panel inside the trailer with two screws holding it on that needs to be removed to find the valves. These valves are located on the (front) side of the water heater, not the back side (which is visible from outside the trailer) - that is likely why you don't readily see the vavles.
44,070 PostsLatest Activity: Sep 18, 2026
