BenK
Sep 03, 2015Explorer
Thanks for the info and links...
Almost exactly what my architecture is, but am going to up the ICE
and change the gearing considerably...just some of my what if noodlings..
Twin screw forced induction with my design inter-cooler (actually a copy
of a super car's), but designed to sit in place of the current intake
runners to my 7.4L.
Buddy (owns speed shop) and his engine builder thinks very doable
and guessing +600Ft/lb continuous...depending on how well the
inter-cooler works
An OD between the 4L80E and Transfer case to get an 8 speed setup
Batteries...am working with some folks on sodium-ion. Projected to be
less than 30% of the cost of Lith-ion. About the same power density
and size. Maybe smaller as it matures and cost should also drop once
it reached commodity levels...plus much more recyclable than Lithium,
which has a limited supply vs salt...plus salt is NOT as potentially
explosive and a fire hazard as Lithium
Rusty after decades away from my design days in Industrial Motor Controls,
but our inverters were some of the first regenerative braking during
those days...
This is the electric motor or it's little brother I want. Knew they
were also working on it's little brother when I found them consulting
on a military job...About the size of a basketball and 100% duty
cycle at 1,500 HP
Electrodynamics 1,500HP traction motor
electrodybnamnics1,500hp 1,500hp tractionmotor
Tractionmotor
Motor diameter: 25 inch
Length: 10.5 inch excluding shaft
Speed RPM.......Continuous HP......DC Bus Voltage
4500...........1500................1200
2400...........750.................600
1200...........375.................300
600............187.................150
All I need now is to win the Lottery... :B
runners to my 7.4L.
inter-cooler works
those days...
cycle at 1,500 HP
Tractionmotor
