valhalla360
Jul 10, 2018Navigator
What is the length of the garage available? Good chance you can select a bigger cab and make it fit. The RegCab long bed F150 is 228" long. The SuperCrew 5.5' bed is only 232".
I would definetly go 1/2 ton truck over a midsize. The midsize isn't much smaller and you can buy a 1/2 ton with better suspension for towing.
The V8 in the jeep should be enough power unless you get into extreme altitudes.
I would suggest one of the eco-boost (turbo) engine options if you will spend a lot of time in Colorado. Naturally Aspirated engines lose 3-4% of power for every 1000ft above sea level due to thin air, so get up above 10,000ft and you are down by 30-40%. A turbo will compensate by pressurizing the incoming air so you lose very little power at altitude.
44,071 PostsLatest Activity: Aug 30, 2026
