F5Pro
Feb 18, 2020Explorer
CP4 bypass kit
Has Ford ever addressed the HPFP fail in later model (2012-2017) trucks? How common is the bypass kit-do lots of folks go this route?
ShinerBock wrote:ScottG wrote:
For those not familiar with the situation: Bypass kit
Exactly! The kit does not keep the CP4 pump from failing, it just keeps a $1k repair from becoming a $10k repair. This is why my brother was about to install the kit before he traded in his truck. His pump was showing signs of failure and he did not want a $10k repair bill like my cousin and another friend had in their PSD's. At the last minute he decided to just trade it in on a CTD.
The complete repair kit is $3300 and the book time is 18 hours so I think that 10 -12 k number that we hear of is BS. More accurate would be to say it keeps a $1k repair from becoming a $6k repair.
Edit: It could be that if you just have your truck towed to the nearest Ford dealer and pay the bill when its time to pick up the truck you'll be dinged with a 10 - 12k repair bill but I know that is not how I would handle it if it were my truck.
Grit dog wrote:
I think it's a good addition (without data to back it up personally) ot insurance. $300 vs $10k is an easy choice in my mind. Like dropping $200 on a secondary fileter for my 5.9 Dodge. Did lack of filtration kill my injectors in 120k miles? Idk. Will I put more than another 120k miles on it? Thought i was back in 2014, but now she sits and only gets one oil change worth of miles a year.
What I wonder about the bypass kit, looking at the schematic...
Before the kit, all the fuel ran through the whole pump providing lube (and cooling?) to the pump. Then when the pump spit it's guts (which has been revised in the CP4.2 design), the guts went out with the fuel to the rail.
With the new design, does the pump just run on whatever fuel is left in there? Ie, getting dirty/old/contaminated?
Also, why has S&S not marketed a kit for the Duramax, same pump, same issues (but purportedly better warranty coverage)?
ScottG wrote:
And I too, wonder why there's no kit for DM or Cummins.
Repair kit EC3Z-9B246-B price varies greatly from the dealer to online stores. Then there is the factor whether your injectors and pump are still a good core or not which could increase the cost to $5k. In most cases, not all of the cores are good enough to return so you will be paying extra for that.
Labor rates also vary at our several Ford dealerships depending on severity. You also have to add time for dropping the tank along with environmental fee for disposing the diesel. This cost varies depending on how much fuel was in the tank. You also have the cost of a fuel filter change(which does not come with the kit) and to flush the lines from the tank to engine.
Add it all up along with tow charge and a 6-10% sales tax then you are very well sitting at or near $10k based on on the repair orders in our shops.
Edit: The cost of the kit varies depending on year.
EC3Z-9B246-B is from 2011-2014 and cost around $3,300 plus core
FC3Z-9B246-B is from 2014-2016 and costs around $4,300 plus core
Last year, my company has sold over 50 of the EC3Z-9B246-B and 5 of the FC3Z-9B246-B.
4x4ord wrote:
If you put the by pass kit on does it prevent a tow bill, tank removal, low pressure side flush and filter change? All 3 kits (2011 - 2020) online are $3300 plus $1500 fully refundable injector core charge. There is no core on the pump. (I am surprised they include 2020 in with 2017 - 2019, might be a mistake?)
online price
If someone wanted the work done at a Ford dealership Ford would have to provide the kit at the online price or the person could order it online and just have Ford provide the labor. I don't think I would have any preference for a Ford garage to perform the labor if the truck was off warranty. And, as others have said, if the truck is still under warranty putting the bypass kit on might give a reason for the manufacturer to not cover the repair.
It sounds like full flow is maintained to the cam section for lubrication and cooling. Then that fuel is sent back to the tank rather than through the fuel system and back to the tank.
The part that gets me is they claim it doesn't effect your trucks warranty. I would bet otherwise. As one guy commented, Ford looked for any reason not to cover his repair and you can bet they would deny any responsibility if aftermarket parts are attached to thier pump - and rightfully so. And I too, wonder why there's no kit for DM or Cummins.
I would put it on after the warranty expires.
