Huntindog wrote:
Lantley wrote:
Huntindog wrote:
For the cost/effort involved.... Replace it. A failed repair can lead to water damage and a MUCH bigger problem.
There is a lot more effort to replace than repair. Assuming the unit is installed correctly from the start. If it is installed incorrectly you can remove the misinstalled unit and install it correctly.
If the unit is installed correctly, then repairing is a much easier way to deal with it.
To get the base out: the door needs to be removed, wall kits removed , plumbing disconnected etc. To do a repair you simply need the right goo, the know how and some sanding. Nothing needs to be removed or disconnected.
The bottom line is the fiberglass and plastics are very fusible/repairable with the correct products. On rare occasions the damage maybe in a non repairable area.
I'm referring to repairs made by a pro refinisher not Harry Homeowner or Roger the RV Guru using some sort of stickum from the Home Depot or a big box store.
Will the pro repairman warranty just the repair, or the damage that results from it's failure?
There has already been one report on this thread of a pros repair failing.
If it is mine, and I like the TT, it gets replaced.
A failed repair can go unnoticed as it slowly works it's damage under the pan.
We all know what that can do.
We can talk about a failed repair much in the way we talk about a failed replacement. Of course if either is not done right it is a waste of time. Replacement is not a foolproof solution if the installer does not address support or piping issues.
A replacement can fail just as easily as a repaired if it is not done correctly. In either case I would like to make the assumption that the work is being done by a competent person.
The OP refers to damage cause by impact not lack of support.
An impact repair is a very good candidate for a repair. When you get into support issues the original unit may need to be re installed and set/supported properly but even then it does not need to be replaced.
As far as concealed damage again the replacement or repair needs to be done properly . Both should be monitored after the work is complete to ensure there are no leaks.
My point remains the repair is a very effective ,viable solution that when done correctly cannot be scene and will last a lifetime.
I'm speaking from experience not hypothetical what if's.
A repair requires a lot less effort and unlike a replacement repair does not impact other items and the potential for collateral issues involved with removing and reinstalling other components
