ticki2
Aug 21, 2021Explorer
silverbullet555 wrote:JimK-NY wrote:
If you have the name and model number you should be able to check the load rating. Don't assume they are suitable because they came off a 1 ton truck. The OP here also had them on an HD pickup.
Plenty of people buy wheels and tires they like without any regard to load ratings.
No! The OP here, me, had a wheel crack. The wheels on the truck are factory original the best of my knowledge. However, I DID buy an extra wheel that was supposed to be a factory GM wheel. It is entirely possible I was sold an inferior product and that is what is cracked. I'll find out this weekend when I pull another wheel off the truck and when I check my second set of wheels in storage.
An original OEM GM PYO aluminum wheel has everything printed under the center cap , no need to pull the wheel just remove the cap .
