mkirsch
Aug 23, 2021Nomad II
jimh425 wrote:mkirsch wrote:
I thought rim ratings didn't matter, rims never break...
Naw, you seem to be confusing adding 200 lbs past a wheel rating with 1500 lbs.
Naw I'm talking about all the "advice" given in this forum to put LT E-rated truck tires on half ton rims and pumping them up to 80PSI on a rim rated for 44PSI.
There's no point to putting an LT tire on if you are not going to air it up. At "half ton" pressures (i.e. 44PSI and under) the tire has no more load carrying capacity than the stock P-metric tires.
