Gjac
Oct 17, 2020Explorer III
mchero wrote:If you look at the top plate there is a small hole that you can put some lube in. I just use WD-40 and stick the red tube in the hole and spray. It is the cheapest solution especially when there is not much worth watching on TV.wildtoad wrote:
I’d try to find out why the crank up wouldn’t crank. If it’s a Winegard it’s the absolute best of a mediocre bunch. Have you lubed it lately? There is an annual maintenance procedure that should be followed.
Absolutely correct! Apparently it's not properly maintained. Those crank up's are the best as long as the head is good and the transformer is sending power to the head.
