mr_andyj
Oct 19, 2020Explorer
it is made of aluminum which can get a oxidation on it and make the gears really hard to move. lubing it might help. I do not know about rubber roofs and lube...
Worst case, go to a junkyard and find an old RV with a working one. It will be cheap.
I had a boomerang on my first on. Like what you would see on an old limosuine. It kinda worked, so I had to get a signal booster to increase the signal.
The crank up is the best as you can turn/aim it, and it raises above your AC unit so nothing blocks it.
Though I have never tried a dome one. sounds expensive...
