poorboy's avatar
poorboy
crank up antenna won't crank up
stayed at a campground this past week that had no cable, so I tried to use the crank up antenna. It was not cranking and not going up. What I would really like to know is, has anybody changed there's from a crank up to a fixed antenna like the ones you see on airstreams. Not interested in dishes or very expensive satellite systems (nothing that good on TV to spend that kind of money). Thanks in advance.
  • I’d try to find out why the crank up wouldn’t crank. If it’s a Winegard it’s the absolute best of a mediocre bunch. Have you lubed it lately? There is an annual maintenance procedure that should be followed.
  • I helped my Son In Law to do just that, he put on the Jack Antenna and to cover the hole left from the crank up antenna you will need This mounting Plate
    Worked out nicely. If you scroll down to the pictures you will see what it looks like mounted. It gets great reception.
