rbpru wrote:
Mine was because the jack nut that rides on the jack screw thread stripped out.
The tongue went down and I had to use the car jack to put the TT back on the hitch.
I looked for an electric jack but opted for a mechanical one. It was cheaper, did not need additional wiring and is the last vestige of exercise I get with a TT.
It was about $40.00 on amazon and matched the old bolt holes.
Just so you will know. No real wiring needed. Just loop the hot wire under the positive battery post wingnut. The jack grounds thru where it bolts into the tongue
