KnowNuthin's avatar
KnowNuthin
CrewCab Long bed shudder
Pulled our GD 303RLS home on Wednesday with our '05 Chevy 2500HD (D/A, CC, LB, 4X4)... smooth sailing the whole way... couldn't be happier...
Got to the house and loaded about 300# of 'stuff' in the basement and as soon as we departed, I noticed we had developed a shudder from the driveline... I'm not 100% sure, but it feels like a driveshaft issue...
Plan right now is to add an Air Lift product to the truck (LoadLifter 5000 Ultimate)... seemed to squat quite a bit as we loaded the 'empty' trailer onto the bed anyway... more forward weight just exacerbated the squat...
Anyone else's truck exhibit this behavior as the 'tipping point' was crossed? Some of the Duramax sites point me in the direction of the pinion-gear angle becoming too great as 'excess' weight is added to the bed... a somewhat common issue... some went as far as replacing the two-piece driveshaft with a one-piece from a late model truck...
  • Since it's only when loaded down I'd be looking at the carrier bearing as well. My old Ram did the same thing. Shimming can cause reaction you may not want ( driving unloaded) launch shudder.
    I went with the one piece shaft and problem went away. I'd give you a link but the company is no longer in business.
  • You may be close to a U-Joint failure or a dry U-Joint. The change in angle aggravated the failing U-Joint and you get the shudder. This happened on one of our trips. Quick change of the U-Joint and the shudder went away.
  • KnowNuthin wrote:
    If I shim the carrier so as to pull the FW shudder-free, will I just transfer the shudder from the loaded to the unloaded state?
    Most likely
  • The truck is smooth while empty/lightly loaded... which is where I spend the majority of my miles..
  • This is somewhat common with 2 piece driveshafts in pickups. Some get it when truck is empty, others loaded.
    As the driveline angles change so can the harmonics when spinning.
    Assuming you have a 2 piece ds.
    Could try shimming the carrier bearing. Usually it's shimmed down for empty or lifted trucks. Maybe there's a washer or spacer you could remove to raise the carrier bearing slightly?
    Just a suggestion if you're pretty certain it's the driveline and all the components, ujonnts and carrier don't have slop in them.
