thejustin
May 01, 2014Explorer
Crooked Atwood Jacks, repair/replace ?
Ok, I bought this 2008 Host Everest about 2 weeks ago. One of the things I noticed was the front jacks are slightly off angle and a few of the bolts were loose. I finally got around to taking it to the RV shops for an estimate and was astounded by the different answers. The first shop initially estimated about an hour of labor on each front jack for repair to straighten, so approximately 280 bucks at ~ 140 an hour. He then looked inside the camper and the passenger side jack apparently is underneath the shower tub in the bathroom. He then told me he would need to completely lift out the shower tub and surround to work on that particular area and similarly remove the panel by the cabover and fridge area to get to the driver side jack area. In any event, he said after all was said and done it would be approximately 1800-2000 for repair. That's more than a set of 4 brand new replacement jacks! I mean, hell, I would just as much prefer to buy a brand new set of Reico Titan jacks and have them put on there.
Took it over to another RV shop and he told me drilling new mounting holes to try and straighten the jacks is going to cause more trouble than good. He suggested I go through each bolt, removing one at a time, dip in silicone sealer and re-tighten and said they were fine. (this is actually a more reputable dealer than the first one so I trust his opinion more) I was in the process of doing that today and every bolt with the exception of one tightened down very good. This very top bolt on the passenger side jack has an enlarged hole and the bolt won't tighten. My friend recommended perhaps using a bolt one size larger and then using some kind of sealant like "liquid nails" to make it water tight.
I took some pictures but its kind of hard to emphasize the problem in a still photograph. Add to that the camper is not sitting level on my truck in the driveway at the moment and it makes it even harder to photograph but I tried to take some to get some opinions. If you look at the driver side mount itself you can see it was put on there cockeyed from the factory.
I'm getting airbags installed next week and need to take the camper off the truck, don't want the damn thing toppling over on me lol. I have had it loaded and unloaded about 4 times in the past 2 weeks and it seemed fine (this was before I noticed the loose bolt), however, after now knowing about that loose bolt and the one shop wanting 2 grand to fix I am afraid to take it off my truck.
Any way, any opinions out there guys???
Here is the problem bolt, you can see the enlarged hole behind.
Passenger front jack
Driver front jack
Here is a picture of how I store it. 4 burro brand saw horses rated at 1500 lbs. each gives 6000 lbs. of support. Took this picture a few days ago. I normally lower the camper until maybe 60-70% of the camper is on the horses and the jacks are still touching the ground.
Driver front jack
