VolantDogs's avatar
VolantDogs
Crossover SUV trailers
Hi all,
I have a 2020 Chevy Traverse with Tow Pkg.
It has a towing capacity of 5000lbs. Max Tongue Weight 500lbs. Payload of 1584lbs. My vehicle is about 78" wide and 70" tall with a 120" wheelbase. I will be traveling with just me and the dogs and their gear, so a higher end estimate would be 5-600lbs in the vehicle fully loaded for a long trip, so it seems that the tongue weight of 500 is probably my most limiting factor here?
I have been looking for travel trailers around 2500lbs or less UVW so that fully loaded we will mostly be around 3000ish (I travel pretty light but there's a good margin here anyway)
I'm looking for feedback on: how important is the size/shape of the front of the trailer? I am looking in the 15-17' range, single axle, low tongue weight trailers. I am aiming to find one that is 7' or 7'6" wide and not super tall either. Would love to have an awning but probably could live without. Same with a dry bath - preferred but wet bath is ok.
I think the easiest to tow ones I have found are things like:
Sunray Classic 149 and Bushwhacker Plus 17D or 17FL. These are both low in height, narrow (7' or less), and have nice curved shapes. Both wet bath with no awning. Seem like they'd be very easy to pull and not harm my vehicle over time.
What I'd like is something with a bit more open "feeling" floorplan and a real awning, such as the Riverside Retro 135 or Sun-Lite 16BH. These units are curved in front but not in rear, and are about a foot taller and 6 or 8" wider. Would this matter much?
Also considered things like Jayco SLX 145RB, Coachmen Clipper 14CRB, Geo-Pro 15TB, but will take other ideas into consideration if there are brands offering small well balanced trailers I could tow safely!
Help appreciated!
RW & the traveling canine crew!
  • “I'm looking for feedback on: how important is the size/shape of the front of the trailer?“
    Power won’t be an issue IMO, so no need to be picky on the trailer’s aerodynamics. I believe you have under estimated the trailer cargo weight you’ll carry (water, propane, batteries etc.) but even with 1000 to 1200 pounds you should be under on max tow and payload weight of the Traverse. I suggest you reconsider a single axle trailer. Two axles can more easily carry the weight and make blowouts more manageable.
