quarky's avatar
quarky
Crossroads 331bh outside kitchen not plumbed to grey tank
hello,
looking for some guidance on my recent purchase of a 2017 crossroads sunset trail 331bh. the outside kitchen doesn't have a grey tank. even tho the termination valve is labeled "grey tank" on the handle. however it only has the termination valve "obstruction" which has to be open to drain or the sink will backfill also then noticedthere is no "grey tank 3" on the sensor panel...
so since this unit is certified according to RVIA ref plumbing nfpa 1192 this does not seem acceptable.
" 7.2.1.2
The waste outlet of all plumbing fixtures, other than toilets, shall be equipped with a drain fitting that provides an unobstructed waterway."
now... the service manager at crossroads rv says that that is the design of the unit and that code doesn't require a grey tank for an outside kitchen. I don't think this is right and would like feedback from the experts.
  • As a CPE, sounds like your unit is "equipped with a drain fitting that provides an unobstructed waterway." No reference to the storage of said gray water.
