Need-A-Vacation
Aug 13, 2016Explorer
D,
Not real familiar with either model, by some things to also compare in addition to the construction.
Axle ratings and gvwr. Do the 2 axles add up the gvwr or did the manufacture add the dry tw to the axles rating for a higher gvwr?
Tire rating and size. Does one have a better tire size for replacement selection and weight rating in relation to the gvwr?
Amount of storage and size of storage doors.
If you truly feel one is a better quality trailer build wise, I would probably lean towards that model. Maybe look at other trailers from both manufactures to see if the one happened to be a "bad build" by chance.
If they are at two different dealers, is one seem to be better than the other for any after the sale issues???
Good luck shopping!!!
44,071 PostsLatest Activity: Aug 23, 2026
