Christl
Oct 22, 2015Explorer
Crown Designed Into Chev and GMC Truck Beds
HI Folks: I just came away from the Towing Forum and found out that Chev and GMC Trucks have been designed to have a crown designed into their truck beds (truck bed is not flat lengthwise). Link http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28594661.cfm
I just checked my 2015 3500 GMC and it has what appears to be as much as a 1/2 crown in the middle. It is my suspicion that this crown has contributed to the popping up and down of my overcap truck camper when driving down the road (Lance 1181). The existence of this crown maybe further be supported by the fact that I have a noticeable decreasing distance toward the rear between the top of truck box rails and underside of the camper when loaded. Since the COG of my camper is marginally behind the rear axle this would exacerbate the tendency of the truck camper overcap to pop up and down while driving. Hear we are trying to reduce overcap popping by installing Lance struts attached to the hood hinges while the truck bed could be contributing to the problem. I am now running with a 1/2 inch sheet of plywood under a heavy 1/4 inch rubber mat and am contemplating gluing a 3/8 inch thick sheet of 4'x2' plywood on the rear half of the existing plywood to help level out the truck bed. Has anyone run into this yet and how have you or would you address it?
