cummins2014
May 14, 2017Explorer
Cummins12V98 wrote:Ron3rd wrote:Cummins12V98 wrote:
1 1/8" 6 point socket 1/2" drive, 1/2" wobbly, 10-12" 1/2" extension and 1/2" ratchet. That is for the front filter. Oh a pc of tubing to extend drain bucket.
For the rear a filter strap wrench, Lisle 6 point wrench to remove sensor and drain hose.
Start to finish 30-45min for both with proper tools. AMAZON has the below.
Dodge Ram 6.7 Liter Diesel Fuel Filter Water Separator Set Mopar OEM
Sold by: Athens Dodge Chrysler Jeep
$70.00
Lisle 34900 OEM Water Sensor Wrench
Sold by: Amazon.com LLC
$9.97
Cummins; that's exactly the combo I bought off Amazon, the Lisle water sensor wrench too. Thanks for the list of tools too.
A guy on youtube had the idea to extend the front filter hose with clear tubing (36" long) to replace the stock hose. This allows you to drain the filter in a pan without fuel going all over the chassis with the short stock hose. Looks like a good idea. Getting ready to change the filters next weekend.
MeAgain gave me a pc of hose that fits snugly inside the front hose extending it down to hang in a container on the ground. The same hose will slip over the water drain on the back filter. Maybe he can chime in on the hose size.
FYI a 28MM 6 point will also work.
Glad you mentioned the 28mm, although not a lot of difference, it is a better fit . Only reason to use a 1*1/8 six point socket is if you have one, would not even consider one if buying , I would get the 28mm.
44,030 PostsLatest Activity: Feb 04, 2025
