FishOnOne wrote:
Cummins12V98 wrote:
Stick with FleetGuard/MOPAR filters!!! Stick with the StrataPore oil filter.
Geno's is a great place to spend your $$$.
Bottom line use OEM especially the fuel filter and don't skimp on the air filter like many do. Don't forget the transmission service.
Good luck...
Bottom line, don't use OE fuel filter. This is one area Dodge screwed the pooch on the Cummins trucks there are better options that are safer for your injectors, but at 150k if stock filtration, injectors are likely about done for anyway.
