Greene728 wrote:
I have a question? You have an even MORE complex engine that in most cases is also MORE expensive to repair with even the cab designed to be removed for major engine work as it’s impossible to do through the top. Why don’t you drive a 6.2 gasser instead?
I mean with CP4 fuel pumps, glow plugs breaking off, EGR and DPF issues, turbo needing replacement, expensive future repairs and all?
Don't stoop to his level. This is not about bashing the Powerstroke either. All three are good engines and have their own pros and cons depending on what you need/want out of a truck.
