New truck, with off road package, has a low air dam. The manual says to remove it when needed, only 15 screws holding it on. While I'm no Jefe or Whazoo, I'm never exactly sure where I might end up wh...
In some vehicles, the air dam is also to direct enough air to the engine radiator for cooling purposes. Although, with the temps newer engines run at, I am amazed that they don't cook. There seems to be no place for the air to go after picking up heat from the radiator and A/C condenser. But yes! I have scraped my "dam" dam on brush and when going thru erosion ditches off road.
