dmullen wrote:
Walaby wrote:
Ok. Im with dmullen. Im leaning towards Kumho's. Next thing for me to look at (after verifying fitment), is actual tire mounting. Should I jack my trailer up, put it on jack stands and take all four wheels in, or do you guys take your trailer to the tire dealer and have them do it there.
Im a little concerned about them not jacking it up properly, so Im actually contemplating buying the tires, and then take the tires, and my trailer, to my RV dealer and have them do it. That way I don't have to fool with jacking it up in my driveway and doing all the back and forth.
Just trying to figure out the lesser of two evils. Hook up trailer, haul to RV dealer, wait to have them done, hook up and come home, or put on jack stands at home and haul wheels to Discount tire or something.
Mike
Good questions.
I need to get my bearings packed. The RV shop said they would take the new tires to the Big 10 Tire next door to them mounted and balanced and then bring them back to install along with packing the bearings. Sounds like a plan I guess.
It's a bit of a different subject, but personally, When I repack bearings, I do it by hand. I do not use the so called ez lube zerk on the end of the spindle. Other folks have had good luck using the zerk, but I have seen them blow grease past the inner seal, and then you've ruined the brakes.
