dmullen wrote:
What do I need to tell the RV shop about how I want the bearings packed that will assure it is being done right? I know nothing about this.
I would ask them if they "pull the drum, remove and clean bearings, hand re-pack, install new seal, and re-assemble" ???
Or do they simply. "pump grease into the EZ lube zerk" ??
This is also a time when they should inspect the brakes while it's apart, and re-adjust the brakes after it's all back together.
This may all sound daunting to you, but it's not. I can do all four of mine in about two hours. And I am old, slow, and take my time.
