msiminoff
Oct 16, 2015Explorer II
Would/could you test and post the power draw on 12 volts (either in watt hours or amp hours) over a 24 hour period after it has cooled off?Yes, I will absolutely do that. I can even data-log the consumption using the output from my TriMetric. However, I'm currently on the road with the TC, so it will be a while before I can do this since I can't isolate the fridge from the rest of the system.
...can you post a pic with the new unit installed?Here you go...
Could you have cut up the old unit and avoided removing the camper door when removing?
I guess that would have been an option, since the Frigo fits through the door frame. But the Dometic is still 100% functional and I'm hoping to be able to re-use or sell it.
Cheers,
-Mark
44,066 PostsLatest Activity: Apr 16, 2026
