NRALIFR
Sep 07, 2018Explorer
I just put this update on my Redarc DC-DC Battery Charger topic on Tech Issues if you’re interested.
“I’m really liking this Redarc DC-DC charger.
I’m in California right now, Desert Center to be exact, where today’s high was 113. Driving from Phoenix today the fridge was running in DC mode, and for the first time in the 15 years I’ve owned this TC, the fridge was holding its own in extreme heat using the DC heater.
Temps in the fridge bounced back and forth between 35 and 38. It may have even been cycling off and on. When it’s in DC mode I can’t tell when it’s cooling as easily as when it’s in AC mode because the battery SOC meter on the front of the camper stays with it’s highest indicator lit all the time. When we stopped this evening, the Trimetric said the battery was at 97%.
I have to say that despite the Redarc’s painful price, and a slightly difficult installation process due to the limited amount of space available in my camper, I would highly recommend this to anyone needing to improve the charging performance to the camper battery from the truck alternator.
Remember, you must follow the manufacturer’s recommendation regarding wire sizing based on the length of the run from the truck batteries to get the full rated charge amps from the Redarc.
Remember also that this unit has a built in MPPT solar controller, and I could install a panel on the roof and connect it to the Redarc if I wanted. I may try that some day.
My only question now is “Is it reliable?” I’ll let you know.
For now, I give it a thumbs up!”
44,066 PostsLatest Activity: Oct 04, 2013
