enblethen
Mar 16, 2016Nomad
26.4 is not correct. It should be closer to 12.6
Disconnect from shore power, NOW. It may even too late.
How many batteries do you have? If you have two they are not correctly connected together.
The positive of one battery should be connected to the other. The negative should be connected to the negative of the other.
The positive of one battery should be connect to the rig.
The negative of the other battery should be connected to ground.
44,066 PostsLatest Activity: Oct 04, 2013
