daddyfarlessa's avatar
Oct 11, 2017
dead batteries
I have a 2014 Airstream.It has 3 solar panels. I use to live in S.Calif where the solar panels kept my 2 batteries always in full charge; most days were sunny there. Now I live in N. Calif and there is less sun.When I go to use my trailer, the batteries are dead (even though I have solar panels).Should I disconnect the batteries after camping? Thanx, Mark
    How long (number of days) does it take for the 2 batteries to go dead?
    What size are these 2 batteries?
    What is the battery voltage that is left when you call them dead?
    Have you ever put an amp meter between the battery and the camper leads to measure the amount of current drain coming from the camper when you are in a camper storage mode?
    2 batteries going dead should take a real long time unless there is a drain on them coming from the camper or very cold conditions. Usually everything inside the camper can be turned off expect the LP gas detector that has no switch. And even the LP detector will over time, drain a battery. But the solar I would think overcome the LP detector without much problem.
    This sounds like something in the camper is pulling way more power then the solar can put out or should be. You may have gotten by with it before as the higher sun output was masking the larger draw. And or, now something else is left on inside the camper creating a larger draw.
    By chance does your refrigerator have a sweating condensation moisture strip? My Dometic fridge does and the moisture strip is actually a 12 volt heat strip. I always have that off or it will drain a battery fast while boondocking. The roof top antenna power booster needs to be turned off too and pull the fuse on the radio.
    Hope this helps
    John
  • If the batteries are 3 to 4 years old you may have one or more bad batteries or cells that affect the ability to stay charged even with the solar. I find with today's batteries I'm lucky if they last more than 4 years in my RV.
    With solar even on cloudy days you should get some juice from the solar panels to recharge or keep your batteries charged.
