Just to follow through on my comments on this thread, we got our repaired Excursion back from a Ford dealership on Saturday, Mar 22rd.
We decided that it was cheaper to repair than replace the entire vehicle with a well "experienced" stand-in, which is essentially like buying a chancy unknown, used motor, especially at this lower, under $10k price range. Besides, as others on here noted, the Excursions are becoming somewhat rare. Actual listed load capacities are well under-rated, and easily improved after only minor modification. The HD frame itself is equivalent to some F-450 trucks.
The new engine is somewhat quieter and just as smooth running as the old one. For the five years we've owned it, the old engine had what sounded like slight worn lifter noise when cold. Power performance was still good to the end, but the Ex did burn a quart of oil about every 2000 miles when towing. The mileage now stands at 118,400 and was at 108k when we got it. After break-in, I may find sudden better "towing" power as a gradual degradation is harder to notice.
We chose a Ford OEM remanufactured engine because Ford seems to offer the best warranty at a competitive price. Ford offers 3 years, with unlimited mileage and no exclusion for use in HD commercial service. Although our fuel-thirsty truck will probably never get very many miles in any type service, Ford's extraordinary confidence in quality inspired our basic confidence. Ford also seems to offer a better labor rebate for any warranty service that may be needed nation-wide, hopefully making any warranty claim a more welcome reception.
A local Jasper Engine installer, in a medium sized shop, estimated a cost just over $8000 (per engine installed only), while the Ford dealer bid $7700, including a new starter (the old starter recently failed to crank in extreme cold unless I put a heater under it). Actual Ford remanufactured engine replacement cost was $7730 plus tax, or $8050.22 total. The Ford engine alone was invoiced at $4373.33, instead of the $5200 that Parts 1st quoted me. It may have seemed initially cheaper to have a small shop do the new engine install, but in case of a multi-thousand dollar warranty argument, I feel more comfortable up against a larger shop with deeper pockets. I believe a small Mom-and-Pop shop would have difficulty absorbing a full $8k in case of a "faulty-install" warranty declaration by Ford (or any other brand rebuilder).
WHAT HAPPENED TO THE OLD ENGINE?...:
I am an intensely curious person. The initial agreement was that the Ford dealer would pull the pan, call me and I would be able to personally inspect the open crankcase of the failed engine right on their shop floor. In reality, I had early doubts this opportunity would actually happen, because I know the hurried technicians often work by commission, and I expect they would resent, and avoid, this extra "wasted" time. Unfortunately that may be why the Ford dealer shop didn't notify me or even open the engine at all. So the real cause of lost-oil-pressure-while-idling remains a mystery. I would have liked to leave all readers with some valuable insight, so sorry 'bout that.
After we made the final decision to just replace the yet undiagnosed engine, there was nothing to lose by trying to restart it, and in case of recovered oil pressure, simply drive it to the dealers shop rather than tow again (we towed it home). That is exactly what happened. After a start, the oil pressure quickly returned to normal, almost identically as it would after a brief instant following an oil/filter change. The engine then ran reasonably quiet and smoothly to the shop where I left it idle a bit to semi-warm-up while I went inside. A service advisor came out, listened to it at my request and agreed it ran quite well. Still, I had no faith it would continue to do so.
It took a few days for the new engine to arrive and the Ex was in the shop a couple of days before the dealer called to say it was ready on Friday. They initially forgot to install the new starter (a bit disconcerting) thus the actual next-day Saturday pick-up date.
Since they did not let me analyse the open crankcase, the service manager did let me at least talk to the technician. The tech said that he thought there was coolant in the oil when he drained it. He had no idea why this would be so.
I have some doubts about this coolant theory, since the oil did not appear milky when I checked the level right after the oil pressure failed. I also do not see how this would cause total loss of pressure at idle unless there was a huge quantity of coolant in the oil. The oil level was right properly where I expected it to be, rather than high as it would with significant coolant added to it. The coolant system was also still full enough for the heater to work on the way to the shop. Loss of coolant, if any, had to be minor.
I inquired if the sump could have been plugged by plastic nylon bits from the cam chain guides, but the tech assured me that failed cam tensioners are very noisy from chain slap, and I believe that to be true too. The old engine still ran quiet, so if plastic bits are in the oil, it isn't from total guide failure because we both agreed the failed engine was not noisy. He drove it in the shop. There remains the possibility that a crank thrust washer fell out into the pan, but that possibility doesn't really account very well for thee brief loss, and return of, oil pressure.
Eight thousand dollars later, the precise cause of the entire episode is still a mystery to me. With a little luck, the aging tranny will hold; it's the only really expensive thing left, knock on pavement.
Thanks to all who commented with suggestions. It did help to make the decision more palatable, the decision to repair the elderly King of SUV's.
Wes
