GWolfe's avatar
GWolfe
"Death Wobble" updated, fixed
I've heard about it but never experienced it until recently.
We have a 2017 F250 4wd at work with around 26,000 miles on it, gas engine. At any speed above about 45MPH the steering wheel will start to shake, some times pretty bad. It takes a bump, like an expansion joint on a bridge, to get it started, sometimes it will be a little wobble in the steering wheel that goes away, other times it gets bad enough that it is hard to control the truck until you get it slowed down to under 35MPH.
We had it into the dealer who told us that a fix had just been figured out and that we were waiting on parts and sent us on our way. The service adviser said that he hoped a recall would be coming but he wasn't holding his breath.
I was just wondering if any of you had experienced this and what you did to fix it? Right now the truck is stuck to city streets with no highway driving which really adds to the drive time when you have to go across town.
We have four F250s in our fleet ranging from a 2005 with the 6.0l Powerstroke, an 08 with the Triton 5.4l, and two 2017s with the 6.2l gas, this one truck is the only one with this problem. Funny the other three are used as plow trucks in the winter, this one just sits.
  • The Rams were famous for this issue. We have 140 K miles on our Ram, and it showed “zero” evidence of front end issues......never even have done a front end alignment! Then, 2 1/2 weeks ago .....we experienced a tie-rod separation! Thankfully, we were going very slowly on a snow covered dirt road, and we weren’t towing our 20K pound 5th wheel.....only a utility trailer with our Polaris Ranger onboard! It’s a bit unnerving when you have absolutely “zero” control of your rig!
    I said all of that, to say all of this..... “get a good mechanic to do an inspection of your truck! memtb
  • I had the same thing happen with my 2001 Dodge truck, different brand I know,but it relates. Running 70 mph crossed a bridge and thought the fenders were going to fly off, stuff in the cab flew all over.
    Pulled over checked what I could found nothing missing. Decided to go to the next exit, much slower of course. Next bridge, same thing.
    Anyway, made it to the next exit, looked truck over, checked tire pressure, all tires 15 pounds low. Aired tires up to proper pressure and have not had anymore problems,that was a couple years ago.turned out my pressure gauge was bad, that's why all tires were low.
  • Steering stabilizers are just a band aide to any death wobble issue. The cause is always worn drag link, track bar ends, ball joints, or the caster being off. The super duty pages on Facebook are blaming it all on the degree of the caster shim and changing that out to the correct one is supposedly fixing this issue. You many want to look at the FB super duty pages and search for more info on this.
  • According to the answered questions this only works on lifted trucks, minimum 2 inch lift.
  • Steering stabilizers are pretty much a sure fix for any vehicle that starts doing that from Jeep size to Class A. They are not that difficult to DIY and just work every time, even if the front end is totally worn out.
    https://www.amazon.com/Rough-Country-8749130-Steering-Stabilizer/dp/B07CTVKY1V/ref=sr_1_7?keywords=steering+stabilizer&qid=1578492551&sr=8-7
