Grit dog wrote:
PastorCharlie wrote:
My 87 Jeep Wrangler YJ started the death wobble a few years back and I took it to a national tire shop and they did an alignment but it still had the wobble. Took it back to them and they rechecked it and said they needed to shim the axle so I told them to do so. They said they tried to order shims but could not find any available.
I took the Jeep to a fleet truck shop that only works on big trucks and they agreed if it would fit their machine they would work on it. It fit and they shimmed the axle with shims they carried in stock and it stopped the problem.. I have not had any problem at any speed or on any highway.
This was likely a caster issue. Lifted springs?
Yes many things can cause it.
Yes leaf springs and front end is in excellent condition. Just illustrating that improper alignment can also cause the problem. Not just any shop can correctly align one.
