aftermath
Jul 16, 2020Explorer III
I have an Equalizer hitch and have used it, actually two different ones, for close to 16 years now. The "4 point" sway control comes from the two sockets the bars fit into and the two L brackets they ride on. Look at their website and they will mention lubing up the hitch. Don't use oil, use a white lithium grease. Look at the sockets and you will see friction points above and below the socket. Put a small amount of grease on these spots.
They sell jackets that fit onto the L brackets to reduce the noise. I have never used these but I have put a small amount of grease on the L brackets too. I don't think they recommend this but I have had no trouble in doing so.
It is somewhat counter intuitive to put some lubricant on surfaces that rely on friction to function. Equalizer suggests that doing this will help the noise. If they say it is OK,I am not concerned. If you think that this "negates" the operation I suggest you try this. When hooked up, remove the clamp on the L bracket and try to move the arm.
Again, this works for me. I have over 50K miles on my current trailer and have not experienced any negative affects.
