1oldtruck's avatar
1oldtruck
DEF Gauge
I took my 2014 Silverado 2500 in for service. When I arrived at the dealer the DEF gauge read 29%. After the service it still read 29%. The service advisor said to drive it a few miles and it will reset. I thought it was odd, but went ahead with it. I assumed they hadn't put any DEF during the service, although it was on the invoice.
I returned two days later when the gauge read 27%. The service advisor said they had to reset the gauge. When I left the gauge read ok.
I did a quick search and found numerous posts related to this issue during cold weather only. Has anyone else experienced this issue in 85 degree weather?
  • sayoung wrote:
    as owner of a 2012,I would say they added DEF as the should have earlier and that's how they reset it.My guauge when I run the checks says Good until it gets way down then starts displaying %
    X2-2013
  • as owner of a 2012,I would say they added DEF as the should have earlier and that's how they reset it.My guauge when I run the checks says Good until it gets way down then starts displaying %
  • I know that on Ram trucks the DEF gauge isn't a conventional float because of the freezing temp of DEF. They use a set of sensors at various levels, and computer interpolation when it's between sensors.
    I'd expect that there is a similar setup in the Silverado.
