dedmiston
Jul 15, 2016Moderator
DEF Issues
I drove a RAM 2500 diesel for 12 years until I upgraded to a pre-owned 2014 3500 diesel earlier this year. I knew nothing about DEF when I bought the "new" truck in March. My first introduction to D...
ShinerBock wrote:FishOnOne wrote:
I add DEF fluid at every oil change which is typically 2 gallons using only DEF from a container and at 96k miles no issues to date. And for the naysayers it doesn't mean I would have problems using bulk DEF, but I'm just more comfortable with the container stuff.
You only fill up every oil change? How often are you doing your oil changes. There is no way I could go 15k between DEF fill ups.FishOnOne wrote:
Running exhaust brake is still a common practice on the 6.7 cummins to prevent soot build up in the turbo
LOL!!! Too bad the 6.0L Powerstrokes didn't have exhaust brake to "clean the soot build-up" on them since they were prone to soot build up on the VGT veins. I wonder if you have to run the exhaust brake on the new Powerstroke since it is VGT now too.
