walker111 wrote:
I have a 2012 6.7 and don't care for the gauge at all. Above or under in a 5 gallon tank leaves some leeway and as mentioned you don't want to overfill as I don't put many kilometers on come September and with our climate here the def freezing could cause tank fracture. I know the heater works but not much help on my short commute.
I think the ram has an actual gauge measuring full to empty???
Love the truck but this is only complaint. Minor.
If you purchase DEF from a container I would recommend purchasing the Ford brand spout. It doesn't allow you to over fill and it also snaps into the fill port which holds it in place which is nice. Once completed rinse the spout with clean water, air dry and store it in the large zip lock bag that it came in for the next refill. It works like a champ.
