Huntindog wrote:
FishOnOne wrote:
Huntindog wrote:
I'm glad my GM doesn't work like that. I have been waiting for the message and then adding 2.5 gallons. I don't want to fill it as the high heat here in AZ rapidly accelerates the DEF degradation.
I don't drive it enough to use it up all that fast sometimes. DEF that has gone bad in the tank pretty much means a tow truck to the dealer. Not a warranty item either.
I'm glad my Ford doesn't have the DEF Poor Quality problems. :W
Fish,,,, You do know that DEF will degrade at the same rate no matter which brand truck it is in right?
And you should also know that DEF that has degraded will no longer do the job for which it is intended right?
So degraded DEF in ANY brands tank will cause problems..... The Fed simply won't allow a DEF system that is not functioning properly to let the truck run and pollute.... Even in your beloved Ford.
Hate to break it to ya.:B
Nothing earthshattering here...
I simply fill my DEF using the Motorcraft spout at every oil change. It's that simple... Oh, and no DEF poor quality messages either... Sorry wrong brand that's a GM thing. :W
