NRALIFR
Mar 23, 2021Explorer
jdgreen42 wrote:
Propane tanks have a built in safety . If you open the valve quickly these will sense a leak and shut off the flow. Have you checked this ? Might be your regulator and hoses are not the problem .
The excess flow check valve is in the pigtail (it’s part of the green Acme nut), not the propane tank OPD valve. The OPD valve has a spring loaded shutoff that will not allow flow unless the Acme nut is screwed in fully, but it does not sense excess flow.
