- GdetrailerExplorer III
JWRoberts wrote:
I would buy a cheap one from the big box stores and sit in on a counter and run the hose to the kitchen drain.
:h
There is no such thing as a "cheap" dehumidifier..
$180 is pretty much as cheap as it gets and no matter how cheap or expensive they might be, expect to replace it every 2 yrs.. If you get 3-4 yrs you will want to celebrate that mile stone (4 yrs is my personal best in my sticks and bricks).
Personally, skip the dehumidifier and crack open several windows and even the roof vents slightly. No electric needed and doesn't break down when you least expect.. - Chuck_thehammerExploreroperator error.. or was it Windows 10?
- Chuck_thehammerExplorerLowe's is where I got mine In January 50 pint.
- wrvondExplorer III bought mine from Lowe's. It has a tube and actually pumps the water out rather than gravity feeds. This means I can leave it on the floor and run the drain line up to the nearest sink.
I bought the Hisense 50-pint with built in pump. Works great. - bgumExplorerBe sure to let your gray tank drip. What you describe is widely avail.
- JWRobertsExplorerI would buy a cheap one from the big box stores and sit in on a counter and run the hose to the kitchen drain.
44,055 PostsLatest Activity: Dec 23, 2025
