brholt's avatar
brholt
Explorer II
Sep 08, 2013
Dehumidifies for truck camper
Getting into fall and starting to think about what if anything I should do for moisture in the camper. We are in Seattle so it's wet. We also plan on using the camper weekends.
Possibilities:
1. Just leave the vents open (they have covers) along with the pass through window.
2. Seal it up and buy a small dehumidifier.
3. Seal it up and put in a small heater like an oil filled heater and run it at 600 watts or so.
4. Seal it up and add some of the chemical water absorbers. If only a little moisture probably easier than 2.
5. Seal it up and buy one of those little heater thing they sell for humidity control at rv and boat supply places. Though it seems to me this is nothing more than a little heater or am I missing something.
Thoughts and comments?
  • -Kevin wrote:
    last fall/winter I sealed it up and put in a Eva-Dry 1100 and it worked great till the 362nd day and it died. I tried and was unable to get any help from Eva-Dry for warranty replacement (1 year). I have the 500 that I use when I am using it and it doesn't seem to do anything near what the 1100 can do.
    I just returned from a quick trip with my wife and son in our TC. First time we left all the windows closed with the heat on. Heat worked great, only to awake in the morning to ALOT of moisture. I just ordered on of these to try out.
    Eva-Dry 1100 on Amazon
    Should be here by the time we leave for Gettysburg, so we can try it out.
    a good price, wonder what the capacity is. does it have a hose attachment so you can just drain it into the sink? keep us posted, please.
    bumpy
  • big whitey wrote:
    just ordered a small dehumidifier from wally world ($59 plus tax). it works on 110/12v and is scheduled to arrive,on 9-20. i bought it to control humidity when parked at home,when using the wave 3 heater in the winter and when boondocking during hot/humid days in NC. i will post the results after i have used it for a while.
    received the dehumidifier today. unfortunately it came without the 12v adapter and on 110 was noisier than i expected. long story short,back to wally world you go. thinking about just using a fan to keep air moving those times with high humidity and see what happens.
    I predict that you will just circulate humid air.
    bumpy
