lawrosa
Nov 28, 2015Explorer
no tow haul mode on my truck
keystone bullet 2011 model. m-294bhs
hard deal to pass up. pristine condition and i mean pristine $15,600
Well you dont have the tow package then..
No tow haul mode
No 150 amp alternator
No trans temp gauge in dash
No trans cooler.
No wire harness ( although after market was probably added.)
Although IMO that trailer comes in at 5600 lbs or so according to specs. With 1600 carrying or so payload your at 7500 max on that trailer.
Can your tundra pull it? Sure... IMO.. But get a trans cooler.. A large one , or the largest you can fit.
Also a new hitch class IV weight distribution
You may be up around 800 or so on tongue weight. And remember if you putt 4 people in that truck your payload capacity shrinks..
So if payload capacity on truck is 1400 lbs, and you load up people and gear of 600 lbs, now your payload is 800 lbs. Thats whats left for TW.
Then axle ratings and tires come into play.. Thats a whole calculation in itself.
Then I would say get the truck weights at a scale and compare to the axle and tires weights to see what you can really tow..
All my opinion..
44,056 PostsLatest Activity: May 04, 2014
