BurbMan wrote:
Use your tow/haul button and watch the speed limit on the road. If you shift manually to 2 it will hold your speed to about 45 mph. Drop down to 1 and it will limit you to about 30, no matter how steep the hill is. but that engine is gonna rev! If no sharp curves, I would put it in 2 at the top and let it go. Tap the brakes as necessary. If you see signs for sharp curves, you can brake to 25 or so and drop into 1. Try to use the brakes as little as possible, and watch the trans temps as you descend the hill.
Good advice here.
The only other thing I can add is that if you aren't confident going into a situation, then you probably need more seat time with this rig before tackiling anything that makes you pucker. Experience pays dividends and talk is cheap.
It all says easy but does hard if you are new to the situation and in the moment.
Don't forget, you can manually control just the trailer brakes if needed.
Also, regardless of what others may tell you, there is an unsafe minimum speed on interstates. Don't get too carried away and creep down an interstate grade so slow that you are a hazard to others.
